It is currently Sun Jun 07, 2026 7:53 pm
 Post subject: fuel problem
PostPosted: Tue Oct 19, 2010 11:54 am
I had to bypass the wire harness for the fuel pump and run it to the ignition coil.this is the way it was when i bought the truck.i connected it to the harness to try to get everything original and after a few weeks it quit. i discovered some problem wires and fixed those but even after the harness bypassed when i accelerate the truck will sputter and die. but it will idle just fine.
Any ideas? fuses good, pump works, filter is clean...
TUFFLUV
 Post subject: Re: fuel problem
PostPosted: Tue Oct 19, 2010 12:47 pm
I really doubt you will be fixing the problem. It shouldn't be much of a job to try. Just pull the hot wire which I think comes off the ignition and the one to the fuel pump off and connect them.
If it doesn't help, try looking at the fuel filter and carb float. Also I think there is a small filter INSIDE the fuel pump.
PostPosted: Tue Oct 19, 2010 7:45 pm
On another question, I remembered the fuel filter inside the stock fuel pump.
Users browsing this forum: Bing [Bot] and 61 guests
