It is currently Sun Jun 07, 2026 7:53 pm
PostPosted: Fri Sep 10, 2010 2:05 pm
Can anyone tell me if the crush sleeve for a trooper differential will work for the LUV differential?
PostPosted: Fri Sep 10, 2010 5:30 pm
'84 through '87 troopers used the same 10-bolt Isuzu differential as LUVs, so I don't lnow why they wouldn't.
PostPosted: Fri Sep 10, 2010 5:53 pm
Well then I guess I will give it a shot...thank you for the response!
PostPosted: Thu Sep 16, 2010 10:24 am
The crush sleeves are not the same.... :(
PostPosted: Thu Sep 16, 2010 10:49 pm
Have you PM'd JLEMOND? He probably has the part you need.
PostPosted: Sat Sep 18, 2010 3:16 pm
Do you have a bearing shop near you or an auto parts store that has an parts man that has been there forever?If you can get the dimensions of the crush sleeve he/she might be able to find another crush sleeve that is from another application or another manufacturer.
PostPosted: Thu Sep 23, 2010 12:23 am
I have actually already got another carrier assembly and have installed it...but after looking at it some more it might fit, the sleeve is just slightly different. So i am going to take apart the other carrier assembly and see if it will work.
Users browsing this forum: Bing [Bot] and 61 guests
