It is currently Sun Jun 07, 2026 8:54 pm
 Post subject: Pinion crush sleeve
PostPosted: Wed May 26, 2010 4:25 pm
Does anyone know where I can get a pinion crush sleeve for my LUV's rear differential? I need one ASAP!
 Post subject: Re: Pinion crush sleeve
PostPosted: Thu May 27, 2010 9:54 pm
Crush Sleeve??? Do you mean a Speedy Sleeve...a sleeve to put on so the seal will have a new surface to ride on? If so, NAPA has a huge variety of them and can usually get any you need.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Fri May 28, 2010 1:20 am
Nope, a crush sleave goes behind the pinion yoke on the rear end, you then tighten down the large nut just until it takes a certain amount torque for the rear end gears to turn. This preloads the pinion bearing tension. The sleave slightly "crushes" in the process.
Where to get one? My guess would be at a shop that specializes in changing gear ratios, rebuilding differentials etc.
PostPosted: Sat May 29, 2010 10:03 am
i have tried and so far no luck.
PostPosted: Fri Jun 11, 2010 6:26 am
Is this what your looking for?
http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=SKF&MfrPartNumber=BR30306&PartType=537&PTSet=A
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Jun 17, 2010 10:21 am
I clicked on the link and nothing came up...I checked with O'reillys and they didnt have anything. Same with Autozone, Napa and various differential shops.
PostPosted: Thu Jun 17, 2010 2:17 pm
try typing in part number BR30306 on O'reillys website.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Jun 24, 2010 2:20 pm
It says no results found...and I doing something wrong?
PostPosted: Fri Jun 25, 2010 1:41 am
This part is sometimes called a pinion bearing preload spacer. See if this more modern name for the part gets you somewhere.
Users browsing this forum: No registered users and 54 guests
