It is currently Sun Jun 07, 2026 11:40 pm
 Post subject: Not As Much Power???
PostPosted: Thu Dec 24, 2009 3:34 am
lately my truck has been dieseling everyother time i turn it off or so.
ive timed it and got all new plugs, wires and coil.
also i feel a loss of power. like when i start in first i have some power but not like normal (its like that in each gear) and when i get up into higher rpms it doesnt speed up as much as it should, compared to how much more i push down the pedal.
what could this be??
1980 chevy luv 4x4
 Post subject: Re: Not As Much Power???
PostPosted: Thu Dec 24, 2009 8:53 am
have you adjusted for dwell and points gap?
i know this sounds stupid, but check the mixture needle. make sure its still good
PostPosted: Thu Dec 24, 2009 2:42 pm
alrighty thanx
1980 chevy luv 4x4
PostPosted: Fri Dec 25, 2009 2:10 pm
What kind of gas mileage are you getting? Figaurus is right on with the point gap. Also read through eggs' old posts I think he has your answers. Smarter fellow than me. Merry Christmas and good luck.
1980 4x4
PostPosted: Fri Dec 25, 2009 2:24 pm
also sure the clutch is adjusted i had that happen to me then i missed with the clutch adjuster and wow mine worked better as the clutch get worn down it will slip some time just a lil bit and its like the more gas you put in it just wont go just a thought
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Dec 26, 2009 12:11 pm
Two things come to mind. Is the timing absolutly correct? It should be 6 degrees at idle (900 rpm or less). It should advance way off the mark when you rev the engine a bit. Also suspect a plugged exhaust, muffler or catalitic converter.
It happens!
PostPosted: Sun Dec 27, 2009 4:34 pm
thanks guys i will check those out
1980 chevy luv 4x4
PostPosted: Sun Dec 27, 2009 5:22 pm
also, check all the vacuum lines. a leak can cause power loss.
you know how to change points?
PostPosted: Tue Dec 29, 2009 1:45 am
no idea what a point is actually haha
1980 chevy luv 4x4
PostPosted: Tue Dec 29, 2009 6:17 am
inside the distributor,under the cap and rotor, there is a small spring loaded contact that opens and closes every time the lobe on the distributor shaft rotates. that is the contact points.
they look like this:
you may as well change them out and install new ones so here is a basic procedure on how to do them.
disconnect the battery and the igniton coil lead to the cap.
there are two screws that hold the points in place. loosen both of them and carefully remove the wire that connects to the contact stud.
it looks kind of like this :
see that little stud near the cap clamp bottom left? thats the contact that the points are connected to.
while you are at it, change the condenser too. its that little round bottle looking thing outside the distributor with the wire coming out and connecting to that same stud. has one screw that holds it in place. just be careful when removing it as it holds a slight charge.
take the new points set, and install them in the distributor, but dont tighten the hold down screws just yet.
get a socket and ratchet and rotate the engine by hand until that lobe is in position to open the points.
tighten the left screw a bit but leave it loose enough to move the contact assembly.
Take a feeler gauge and rotate the entire assembly until its only open a specific amount. i think (but im not sure) that mine are set at .016 .
carefully tighten the screw on the right side, and then the left side.
check the gap again. make sure its within spec.
connect the wires to the stud and put everything back together. If you did it right, the engine should fire right up.
see if you can find a dwell meter to set them more accurately.
hope this helps!
PostPosted: Wed Dec 30, 2009 1:35 am
Point gap and timing specs are on the hood... unless your decal is gone.
PostPosted: Thu Dec 31, 2009 2:31 am
wow thanx figuarus will do that tomorrow!
1980 chevy luv 4x4
