It is currently Sun Jun 07, 2026 11:39 pm
 Post subject: what size nut ..
PostPosted: Mon Dec 28, 2009 7:25 am
i need to pull the stock motor. i took off accessories and such but dropped the small cup of bolts/nuts i had removed at the yard where my truck is. i looked .. no luck.
what is the size nut on the exhaust manifold side so i can go pick some up and some washers so that i can have somewhere to hook the chain to pull the motor
and also the circle stud in the picture. what size nut would that be?
i cant wait until this truck is in a more convenient location for me to work on it. i do thank everyone here who has helped me out with my troubles of not having full 24hour access to my truck when id like to
Kyle
 Post subject: Re: what size nut ..
PostPosted: Mon Dec 28, 2009 7:46 am
Take your 12mm metric wrench with you to a hardware store for reference - since that is the wrench that fits the nuts. The same nuts fit both intake and exhaust manifolds. You will be looking for metric nuts and the stud will have the same threads.
PostPosted: Mon Dec 28, 2009 9:11 am
go to the specialty bin at home depot. i got mine from there
PostPosted: Mon Dec 28, 2009 4:36 pm
right but whats the pitch? i cant take the truck with me to find out what fits the studs on the engine
PostPosted: Mon Dec 28, 2009 4:42 pm
It would be best to take a nut off the manifold since they are the same size and take it inside whatever store you go to and match it up. Alot of stores have a bolt/stud board for this purpose. If where you go doesn't have one just try threading the nut on different bolts until you find the right one. Metric of course.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Mon Dec 28, 2009 4:50 pm
77pumpkin wrote:
77pumpkin wrote:
i need to pull the stock motor. i took off accessories and such but dropped the small cup of bolts/nuts i had removed at the yard where my truck is. i looked on the ground.. no luck.
Kyle
i took all the nuts off the exhaust side and dropped them on the ground and there is so much other random crap on the ground i cant find them. grass/gravel, etc
wait .... did someone say that the exhaust and intake studs are the same size????
PostPosted: Mon Dec 28, 2009 5:34 pm
yes indeed
PostPosted: Mon Dec 28, 2009 8:48 pm
ok good. ill just back on or two off the intake side and use them on the exhaust side to pull the motor
thanks guys. as usual .. a ton of help here
PostPosted: Mon Dec 28, 2009 9:15 pm
They are an 8-1.25. Don't buy nuts and bolts at Home Depot, expensive trash. Hit an auto parts store or real hardware. I buy all mine at my local Ace hardware dirt cheap for good stuff.
PostPosted: Mon Dec 28, 2009 9:40 pm
AWESOME! thanks man. i guess i would only need ... 2? so like .. $1? lol
PostPosted: Wed Dec 30, 2009 5:30 pm
got it all taken care of. thanks. motor is out
