It is currently Sun Jun 07, 2026 11:41 pm
 Post subject: stock suspension parts
PostPosted: Fri Dec 04, 2009 10:01 am
looking for a parts list on here for suspension parts for my 72 luv
the only thing ive found so far is the upper and lower ball joints and they were from spicer (expensive)
SPICER
UPPER BALL JOINT
Item No: 500-1041
SPICER
LOWER BALL JOINT
Item No: 505-1118
im also looking for the upper and lower control arm bushings as well as the strut rod bushings. maybe it would be helpfull to all of us if we started a list for crossovr parts with numbers
strut rod
idler arm
torsion bars
if this is already been posted i couldnt find it so if somebody could give me a link. it would be greatly appreciated
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Fri Dec 04, 2009 10:18 am
If you go to http://www.luvtruck.com, in the information section there is both a master parts list and an interchange manual. I use that to see which 72 parts are interchangeable with what other years. I'm frequently disappointed that there isn't more interchange for 72, but nonetheless the documents are very helpful.
