It is currently Mon Jun 08, 2026 12:22 am
 Post subject: water pump
PostPosted: Wed Oct 14, 2009 7:17 pm
is it hard to change it looks hard to change never done it but my luv run really hot and thats the last thing i havnt replaced
75-luv mikado-V8 350 soon
 Post subject: Re: water pump
PostPosted: Wed Oct 14, 2009 11:07 pm
No biggie, easiest way I have found is pull the grill, radiator, and then pull the pump. Not much to it. Flush the system put in new anti freeze, good to go.
PostPosted: Fri Oct 16, 2009 12:21 am
Hmm... why did you pull the grill? I just drained the radiator, pulled it out, and then pulled to water pump.
I was working on an '80. Were you working on a different series? That might be the difference.
PostPosted: Fri Oct 16, 2009 12:37 am
I took off the hood first.. made things waaaaaay easier for my big ass.. :lol:
yeah, took off the hood, the radiator, unhooked hoses, and moved the alternator a little.. No biggie, except for a stupid bolt which refused to come out, if not it would have been super easy.. :D
LUV is...
PostPosted: Fri Oct 16, 2009 1:02 am
Short arms I guess, just seemed easier.
PostPosted: Sat Oct 17, 2009 4:02 am
Alright... understandable. lol, 6'1", and I can grab tools from the opposite side of the truck, but when I have to work under the dash, things get a little tight.
To each his own, right? :roll:
On stupid bolts that refuse to come out: try tightening it just a little, like maybe 1/32 of a turn. Sometimes it breaks the threads loose. lol, an impact driver usually works quite well too.
A little about water pumps: Duralast= bad, NAPA= good. The Duralast one has a sheetmetal impeller, while the NAPA one is cast iron. I learned this one after the 4th time I pulled the whole shebang apart... lol, got it down to under an hour though!
