It is currently Mon Jun 08, 2026 5:36 am
PostPosted: Thu Sep 03, 2009 10:02 am
HELP...after rebuilding the carb, which I thought was the problem, my stock 78 Luv will start but won't keep running. If I hold the key in the start position it will continue to run but we all know what this does for your starter!!!!!!The ignition switch is OK but I don't know what to check next. Suggestions please....
PostPosted: Thu Sep 03, 2009 10:50 am
sounds like you're not getting fire to the coil without the remote wire.. maybe in the ignition switch..
PostPosted: Thu Sep 03, 2009 12:34 pm
Checked the ignition sw...seems to be OK. Tested and cleaned fuse block. Ran a jumper to the coil....new twist today, it won't start at all. Is there a relay I'm missing somewhere. This is a real pain in the a@@....
