It is currently Mon Jun 08, 2026 12:23 am
 Post subject: anti dieseling solenoid
PostPosted: Mon Aug 10, 2009 4:18 pm
is it posed to click when power is applyed to the fuel pump wire?and if i run a hot in run to the fuel pump does it need to ingage also or will it hurt any thing not to work?
if ya always keep ur nose to the grindstone ur gona end up with no nose
if ya think ya cant you are right
PostPosted: Mon Aug 10, 2009 9:13 pm
It needs to engage when the key is on. I believe it is in the fuel pump relay feed circuit, not the output circuit to the pump.
That being said maybe try it and see. If it doesn't power up the engine will die and not idle.
PostPosted: Tue Aug 11, 2009 12:58 am
thanks egg
Users browsing this forum: No registered users and 61 guests
