It is currently Mon Jun 08, 2026 3:11 am
PostPosted: Fri May 15, 2009 3:02 am
I'm a new owner, 81 diesel, in need of help! Removed the window for painting ,but now can't find a replacement. Isuzu pup to 87 should be the same. Any lead would be appreciated. Gene NIelsen gpengine@comcast.net in Downers Grove Il.
PostPosted: Sat May 30, 2009 3:14 am
Not being able to find the "weatherstripping" I took a windshield seal, cut a section out at the top and bottom using very sharp blade, clamped into a cutoffsaw. Glued the ends together using "super glue". Installed the rear slider using the standard string method for window. At first it
seamed a little tackie,but it worked great for me. gengine@comcast.net
PostPosted: Sat May 30, 2009 11:42 am
Good work. It always feels good when you can improvise and make something work.
Thanks for sharing.
Eric Q.
My build thread.
