It is currently Mon Jun 08, 2026 3:11 am
PostPosted: Thu Apr 09, 2009 11:09 pm
When I turn on the lights it makes the master fuse blow. The only way it doesn't is if I disconnect the rear lights from the fuse block
PostPosted: Thu Apr 09, 2009 11:16 pm
Sounds like a short in the tail light wires
PostPosted: Fri Apr 10, 2009 8:06 am
:signiagree that would explain the blinkers not working also.
PostPosted: Fri Apr 10, 2009 8:11 am
Light issue was resolved already but its just the blinkers now
PostPosted: Fri Apr 10, 2009 8:29 am
Probably a long shot but make sure your battery has a good charge. When I switched my front signals to LED I was having a lot of trouble getting them to work until I tried to start the engine. It was completely dead, when I jumped and started it the lights were working fine.
PostPosted: Fri Apr 10, 2009 8:32 am
Yeah I have good charge... Not a battery problem...
