It is currently Mon Jun 08, 2026 4:14 am
PostPosted: Tue Mar 31, 2009 8:04 pm
Where would this be installed???
PostPosted: Tue Mar 31, 2009 11:55 pm
If you're asking where the temp sender is, it's located under the t-stat housing on the bottom side of the intake manifold.
Image1980 4x4, 3" body lift, G180/G180 head, Pacesetter header, Offenhauser Dual Port Intake, Weber 32/36, Electronic Ignition, Glasspack & a Smokestack.
PostPosted: Wed Apr 01, 2009 12:11 am
Even on the offenhauser intake manifolds?
PostPosted: Wed Apr 01, 2009 12:13 am
some came with out the hole drilled, you may have to drill it your self... i know my side draft intakes where that way...
PostPosted: Wed Apr 01, 2009 12:17 am
There's a bolt on the side that if I remove it water comes out... Would it be safe to put it there?
PostPosted: Wed Apr 01, 2009 1:07 am
it should be
