It is currently Mon Jun 08, 2026 5:35 am
PostPosted: Wed Feb 11, 2009 9:39 pm
When I open and close my door the dome light does not work, however if I push on the switch in the door jam several times eventually I will get the light to work and stay on when the door is open. Then when I shut the door and reopen the light does not come back on. Have you guys done any troubleshooting on this. I am assuming a bad switch but wanted to check with you first. Thanks Ryan
PostPosted: Wed Feb 11, 2009 10:35 pm
sounds like a bad or dirty switch try spraying some electrical connector cleaner with a few in and out reps, see if that helps
PostPosted: Wed Feb 11, 2009 10:39 pm
Will do. Thanks for the info. Ryan
PostPosted: Sun Feb 22, 2009 6:03 am
I had the same trouble with mine. They are completely rusted out and the springs are junk
know where i could find new ones?
Image Image
PostPosted: Sun Feb 22, 2009 10:14 am
should be able to pick em up at any parts store probably have to put different connectors on them though
