It is currently Sun Jun 07, 2026 2:37 pm
 Post subject: Repeated question
PostPosted: Tue Jul 22, 2003 5:34 pm
I know this question has been asked many times before, but I'm going to ask it again. What can be done to the 1.8 to make more power? I know about the carb conversions and headers and such, is there anything that can be done internally to improve performance? Does anyone make high-performance cams for the 1.8? I'd like to upgrade to a V-6 one day but I don't know that I'll ever have the time to do the work so I'd like to know what I can do to the 1.8 and just drop it back in. Thanks for any info or opinions you can give.
PostPosted: Tue Jul 22, 2003 5:38 pm
Resident Sparktrician
You can upgrade the cam, if you can find one. The one I'm puting in is from Crane Cams, but is new old stock. I just lucked out and found it.
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Tue Jul 22, 2003 10:17 pm
theres a couple of isuzu off roading shops in california that will do costom cam regrinding.
PostPosted: Wed Jul 23, 2003 6:39 am
Thanks! I don't really know what I want to do with this yet, but I'm getting some pretty good ideas.
PostPosted: Wed Jul 23, 2003 8:36 am
Where in Oklahoma are you? I'm originally from there, but have been gone for about 10 years now...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Wed Jul 23, 2003 12:17 pm
I live in Wagoner. It's a pretty boring town, but the lake is just down the road and that can be fun sometimes.
PostPosted: Thu Jul 24, 2003 7:08 pm
you can bore the engine as i am doing. maybe some bigger valves. i don't know if u can have the head so u can run high compresion pistons but if u can theres another.
PostPosted: Thu Jul 24, 2003 11:18 pm
Brother, I'm from Coweta...
I grew up skiing on Gibbie...
I also used to ride an old Honda Trail 80 in and out of the waterside over there. Damn, there are days I miss that place. However, after seeing what I've seen, I don't think I could ever live there again. I'll be back home around Christmas, maybe we could meet up sometime...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
 Post subject: My 2 cents
PostPosted: Fri Jul 25, 2003 9:32 am
What about just dropping a Toyota 20R and transmission in the LUV. The radiator should work and minor engine mount mods along with the tranny mount should do it. I haven't done one, but for more power, it seems the cost to get the stock engine 'pumped' up would be the same or more than a good old 20R. Again, just my 2 cents.
Rick
PostPosted: Sat Jul 26, 2003 3:02 pm
a 2.4l 22R would be a better swap, since the motor superceded the 2.2l 20R in 1981 and was available in the us until 1995. the engine has practically the same dimensions, since a 22R block is essentially a bored/stroked 20R. wouldn't matter what tranny you used, since 20R and 22R trannies were pretty much the same
i'd say it'd be a good swap, because parts are easy to find and dirt cheap. if you felt like wiring up an ECU you could dump a 22RE in there, with fuel injection. a weber carb suits me just fine though 8)
the motor would fit in there without too much work, probably would just need new or modified engine mounts
