It is currently Sun Jun 07, 2026 3:53 am
 Post subject: motor oil
PostPosted: Sun Jul 13, 2003 11:18 pm
always wondered what happens if u overfill on motor oil.might of done that on my 81 2.2 :oops: was at night.
PostPosted: Mon Jul 14, 2003 5:10 pm
Higher oil pressure, if put in a lot more than needed you could blow out your seals.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Jul 14, 2003 5:50 pm
your seals can blow out, high oil presure, and it might start smoking. If you only ran the motor high on oil for a little bit then there will probly be no lasting damge.
PostPosted: Mon Jul 14, 2003 5:55 pm
little story on overfilling oil:
a buddie of mine got a 1980 ford bronco once (one of the full size broncos) and if you started it up on flat level ground, everything was fine. but if you took it up a hill or tilted it side to side it would smoke like a freight train. had us puzzled for awhile. then he drained the oil to change it. it had 14 DAMN QUARTS IN IT!!!!! 8O ....seems what was happining was. the dipstick tube was gummed up and when the previous owners would check the oil it would wipe it clean. showing it was low so they would put more oil in it :roll:
well after we put the correct amount in it, it rattled and ran like shit. every damn seal in it was blown :x
PostPosted: Mon Jul 14, 2003 7:34 pm
A story from an old mechanic, My Dad
If you overfill you crankcase to a point where the crank's counter balance weight dips into the oil pool it will start to aerate the oil. It may not foam up like a milk shake but will put out tiny air bubbles in the oil. With air in the oil it will lose the lubricating properties and start to smoke the bearing and seals. I quess with air in the (heated) oil would also produce a higher oil pressure reading as a by-product.
He (my dad) worked on the US Air Force Turbo Prop engine so I guess he must of known his stuff back then.
Sounds good doesn't it
:usa
