It is currently Sun Jun 07, 2026 6:56 am
 Post subject: control arms
PostPosted: Sat Jul 12, 2003 7:20 pm
ok some body said the found a way to bag the front end of a luv to get 4 in of lift. but i can only go about 3-3 1/2 cause my upper a arm will hit the rim if its n e higher so does n e one know if there is a way to move the control arms down. i know how to move the axle down but not the control arms so n e ghelp is appreciated. if it comes down to it i will just use wheel spacers or go to solid axles. matt
PostPosted: Sun Jul 13, 2003 1:28 am
Resident Sparktrician
While not directly related to your question (it may be a hidden fix, though), this is something that I would recommend to anyone going to higher lift with the IFS on "Isuzus". I will be doing this when I finish with other modifications.
ball joint flip article
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Sun Jul 13, 2003 8:26 pm
I have seen somewhere a spacer kit and shorter poly bump stops being sold for newer Isuzu stuff. I don't know that newer 'zoo parts would fit, but the spacer seems like a pretty simple torch and grinder project. I'll try to dig out that link, maybe contact them and see if they're interested in making some LUV parts available as well.
PostPosted: Sun Jul 13, 2003 8:59 pm
They should fit all Isuzus as they go by the number of bolts holding the ball joint, and here is a link: ball joint flip kit
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
