It is currently Mon Jun 08, 2026 5:34 am
 Post subject: Passing Smog
PostPosted: Thu Oct 16, 2008 7:09 pm
After I bought my luv a tire blew and tore about 2 feet of the muffler off. Will it still pass smog like this? The truck runs great.
Any ideas on how I should repair it. I cannot weld?
Thanks
 Post subject: Re: Passing Smog
PostPosted: Fri Oct 17, 2008 2:28 pm
You will not pass smog, because thier sniffer machine will nto be able to detect any exhaust.
If you cannot weld, you can purchase a U bolt setup that tightens down on one side of the muffler line and allows you to attach another portion to it without welding. This internet is slow (library) so I cannot look it up for you.
PostPosted: Tue Oct 21, 2008 1:28 pm
or you can take it to the muffler shop and they will fix it just one more option :wink:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Oct 24, 2008 4:48 am
If you just need a quick temporary fix to get through the smog test, bailing wire and a beer can do wonders. As long as you didn't damage the cat the actual emissions should be the same.
Users browsing this forum: Google [Bot] and 45 guests
