It is currently Mon Jun 08, 2026 4:34 pm
 Post subject: speedometer cable
PostPosted: Sun Oct 05, 2008 3:42 pm
I need to replace the cable for the speedo on my 76 but can't seem to get the housing to release from the meter head. It is old and maybe stuck :? but I don't want to break something. A bit of advice is desired. Thanks
Bruce
 Post subject: Re: speedometer cable
PostPosted: Sun Oct 05, 2008 7:58 pm
If I remember correctly, there is a clip you have to squeeze with your fingers to release it from the head.
PostPosted: Mon Oct 06, 2008 7:33 am
Thanks,
I found the squeeze clip right off but squeezing it wouldn't release the cable. I kept squeezing and rotating the clip and suddenly it slipped off. Maybe it had to be in exactly the right place :?: or just needed a bit of foreplay :wink:
PostPosted: Tue Oct 14, 2008 12:46 am
My 75 was treaded
I'd see about taking it loose at the trans and pull the whole cable loose giving you more room up top so you can see along w/ obtaining better tools access.
G'Luck
Mt
