It is currently Mon Jun 08, 2026 7:02 pm
 Post subject: Rewire the whole luv?
PostPosted: Mon Oct 06, 2008 9:09 pm
Has anyone ever rewired their whole truck? If so what resources did you use to help with the rewire? When I tear it down to paint I thought this would be the best time to take this project on.
Thanks
PostPosted: Mon Oct 06, 2008 9:11 pm
viewtopic.php?f=7&t=12924&start=0&st=0&sk=t&sd=a&hilit=re+wire
PostPosted: Tue Oct 07, 2008 1:05 am
Also from personal experience get the ez wire it says what it goes to every inch on the wire just in case ur color blind lol :oops: :roll:
A good friend will bail you out of jail, and even better friend would be sitting in the cell with you saying how awesome that was!!!
PostPosted: Wed Oct 08, 2008 6:00 pm
I'm going to be buying an EZ wire harness soon too. It sounds very user friendly having each wire labeled every 5 inchs. The one thing i thought of first before removing the told harness, is figuring out the wires that go to the plug on the back of the instrumental panel. I'll be keeping the plug with a lit bit of the wire so I can wire that into the new harness.
PostPosted: Wed Oct 08, 2008 6:15 pm
By the way anyone that has bought an EZ, what model did you get for your Luv?
They have a 12 fuse and a mini 12 fuse kit.
PostPosted: Wed Oct 08, 2008 6:23 pm
I enjoy doing electrical work. I have yet to have a problem with my stock harness. I have modified my 76 (V-6) and 74 (V-8). I run the stock fuse box, add a couple new wires as needed and it works perfect.
PostPosted: Wed Oct 08, 2008 7:43 pm
My electrial work has been far from enjoyment. My regulator fuse keeps blowing after the truck warms up. I removed harness, couldn't find any obvious bad wires. Then had myu mechanic look over it. He solderd some wires on the harness near the postive batt. cable and aded an extra ground, and it still would not fix the problem.
viewtopic.php?f=5&t=16677
PostPosted: Thu Oct 09, 2008 2:03 pm
I cant quite remember but i got a standard size but i belive i got more than 12 for some easy add on stuff later but it works like a champ.
PostPosted: Thu Oct 09, 2008 9:42 pm
I emailed EZ about the 12 vs 12 mini. They said you could expand off the 12 fuse block, but not the mini. The 12 runs $170 The mini is $155.
PostPosted: Thu Oct 09, 2008 10:27 pm
If I was going to spend $155 for it, I would go ahead and add in the extra $15 and get the better one. It's not like it's another $100, just $15.
PostPosted: Fri Oct 10, 2008 1:04 am
I got mine for 120.00 on ebay just was really pacient and i got lucky.
PostPosted: Sun Oct 12, 2008 4:05 pm
When I did mine, I believe it was the 12, I also got it off of ebay for around $130. EZ is very helpful, and spent a lot of time with me on the phone making sure I had things right. The only reason I replaced my entire harness was because it had been hacked up so bad before I got it, I was blowing fuses and just got tired of trying to track all the gremlins. Just take your time with it.
Users browsing this forum: Baidu [Spider] and 46 guests
