It is currently Sun Jun 07, 2026 11:00 am
 Post subject: fuel tank
PostPosted: Mon Jun 30, 2003 12:57 pm
i have a question. i was refueling and left my 81 2.2 diesel runing as soon as i opened the tank it seemed to idle faster maybe smother. what could this be? thanks
PostPosted: Mon Jun 30, 2003 8:18 pm
the only thing i can think of is maybe your tank vents are restricted by some debris. when you remove the cap it allows proper venting and the pump doesn`t have to struggle to get the fuel to the motor. next time you take it for a long drive leave the cap off and see if it runs a little better
 Post subject: thanks
PostPosted: Tue Jul 01, 2003 6:13 am
is there anything i can do about the vents . clean them out?? where are they?
PostPosted: Tue Jul 01, 2003 4:14 pm
if there in the same place as the gas models its on the side of the bed next to the filler neck there is an access panel on the inside of the bed. i don`t know if they can be cleaned or not. i `ve never had it apart. my truck is a race deal so i completely bypassed it. if you look at your filler neck under the bed you should see hoses running to it.
PostPosted: Tue Jul 01, 2003 7:50 pm
You would be amazed that spiders like those vent hoses to lay egss and lay webs. Just diconect the vent hoses and clean them out with a hanger or get yourself some pipe cleaners and push them through a couple of times and that should do it. Hope this helps. :)
 Post subject: filter lite
PostPosted: Thu Jul 03, 2003 3:08 pm
my filter lite on my 81 2.2 diesel is on and iv chenged the filter twice already and its still on. what could i be doing wrong?
PostPosted: Fri Jul 04, 2003 12:51 pm
you have a bad connection or a broken wire thers not mutch else it can be.
PostPosted: Sat Jul 05, 2003 9:56 pm
buy a new gas cap and drill a puin hole in it...
worked for me :lol:
