It is currently Mon Jun 08, 2026 2:13 pm
 Post subject: Tilt wheel?
PostPosted: Thu Aug 28, 2008 1:48 pm
Has anyone found a way to put a tilt wheel in a LUV? I'm a tall guy, and could use some extra leg & knee room. There are companies out there that make them, but I don't know if they would work.
Thanks
 Post subject: Re: Tilt wheel?
PostPosted: Thu Aug 28, 2008 3:27 pm
here you go viewtopic.php?f=7&t=14225&hilit=tilt+column
also if you go down to the www link below my sig and look in photos you will see an old truckin wright up on the tilt column in a luv
PostPosted: Thu Aug 28, 2008 11:20 pm
I've wondered if anyone has taken the trooper steering column and put it in the Luv.
As for knee room, I swtiched my steering wheel over to a Grant, and wen twith just a little bit smaller diameter. I coudl see the tilt would be nice too.
PostPosted: Sat Aug 30, 2008 1:00 am
Australian LUV Guru
Thanks
A smaller wheel & power steer conversion would be the way to go. Im 6ft 6in tall and fit comfy with stock bench seat and smaller wheel.
1980 4x4 KBD40 ISUZU/Chev Luv
