Sounds like you're on it.
You might find this interesting, the author is highly respected in the Saab community...
http://townsendimports.com/Web/cooling_ ... ingsys.htmQuote:
We have found increased life and fewer failures of any kind in the cooling systems after using Mercedes Benz factory coolant. It is phosphate free and pH buffered with inhibitors to aid in the prevention of electrolysis. When servicing cars that have been using it, the difference in the appearance of the internal cooling system is noticeable. Upon thermostat replacement, the aluminum is not covered with the white aluminum oxide or pitted from electrolysis as is common with the green coolants routinely used by some.
There is such a thing as too much anti-freeze/coolant. A Google search will provide additional results on this...
http://www.eetcorp.com/antifreeze/antif ... aq.htm#q22Not to be a jerk, but some of the info you're getting locally sounds like it might be incomplete/innaccurate. A lot of times people are a bit lazy, I'm not sure why a MB guy wouldn't want to sell his coolant. It really does do wonders in older vehicles. It takes a while, but too much coolant usually causes accelerated water pump wear. I'm not ASE certified or anything, and I am not the world's greatest mechanic, but this is an area I've had a lot of problems in also (did I mention I've owned a lot of Saab's?).
Sounds like a recore or new rad will take care of this, possibly just adjusting the timing will settle things down.
Good luck, keep us posted on what solves your problem.
