It is currently Tue Jun 09, 2026 11:03 am
 Post subject: half moon seals
PostPosted: Thu Jul 24, 2008 11:27 pm
any one have a good fix for leaks around the half moon seals on the head... mine are new and still leak... i tried some gasket seal but it got hard and brittle and still leaked
 Post subject: Re: half moon seals
PostPosted: Fri Jul 25, 2008 3:00 am
Try using just enough high temp silicone to cover the little grooves in them before you install them. Works for me.
PostPosted: Fri Jul 25, 2008 7:05 am
thanks
PostPosted: Fri Jul 25, 2008 8:17 am
I have found that a silicone called "The Right Stuff" made by Permatex is the best stuff out there right now. I have yet in a couple of years had a leak any place I used it. It is alittle bit more money then the others but worth every penny.
PostPosted: Fri Jul 25, 2008 9:25 pm
ill try to get some ... where at?
how long after its on do i have to wait to drive again
PostPosted: Fri Jul 25, 2008 10:32 pm
I saw it at Pep Boys. It's in a "Cheese Whiz" style can. I have not tried it yet.
PostPosted: Fri Jul 25, 2008 11:21 pm
found some at autozone $13.99 no set time can use instintly
PostPosted: Sat Jul 26, 2008 7:28 am
So did you try it on Ritz crackers yet? :P
PostPosted: Sat Jul 26, 2008 10:16 am
That'll prolly stick tuh yer ribs.... :lol:
PostPosted: Sat Jul 26, 2008 7:00 pm
stuff works great ....no leaks, thanks :lol: :lol:
PostPosted: Sat Jul 26, 2008 9:35 pm
It's the best I have found, I will pay the extra $$ for it everytime.
PostPosted: Sat Jul 26, 2008 11:33 pm
its my new best friend... worth the extra $$
PostPosted: Sun Jul 27, 2008 3:23 am
That stuff is the best....without a doubt.
BTW Cat...wheat thins are probably a better choice over ritz crackers. They will give you a lot more roughage which you will no doubt be needin' by the time you finish off the whole can.
PostPosted: Sun Jul 27, 2008 9:27 am
:lol: :lol:
PostPosted: Sun Jul 27, 2008 10:24 am
If you put that stuff on any cracker you would not need to worry about being regular, it would seal that side also :ebiggrin
PostPosted: Sun Jul 27, 2008 7:54 pm
took it on a 200 mile trip and had it up to about 80/90mph and not one drop... I also redid the breather , fuel return (opposite ends of the air cleaner) and crank case vent just like it was stock but with the weber… all info was in the factory manual, so now I have no blow by any where :lol: :multi: :smt026 :smt041
PostPosted: Sun Jul 27, 2008 8:17 pm
There must be something to that stock ventalation system, reminds me of a earlier post.
PostPosted: Sun Jul 27, 2008 8:24 pm
yes... when it is plumed right it make a slight vacuum in the valve cover keeping the blow by from coming out the breather.. And most of us that put the weber on gust block everything off that’s where the mistake is
