It is currently Mon Jun 08, 2026 6:54 am
 Post subject: Proportioning Valve
PostPosted: Sat Jun 21, 2008 10:04 am
I have a 81 luv diesel. My brake light is on in the dash and I have traced it to the Prop. Valve.
Can someone tell me the proper procedure for resetting it?
 Post subject: Re: Proportioning Valve
PostPosted: Thu Jul 17, 2008 8:49 pm
if you haven't figured it out or been pmed i notice you've had no responses. try cross bleeding the brakes. if you're unsure what that means, bleed right rear left front left rear and before letting the pedal up on the left rear open and close left front that should clear your light
