It is currently Mon Jun 08, 2026 6:54 am
PostPosted: Fri Jun 20, 2008 5:06 pm
Last night I was changing my radiator hoses.. I was using a hose to fill the radiator up when water splashed and went all over the engine while it was running.
The engine died, and when I tried to crank it it wouldn't idle and would suddenly die like it ran out of gas. Worst of all, the GEN light was on and didn't turn off. So I went to bed (9PM) and got up for work (4AM) and it STILL was doing it! I had the keys and had to open up shop so I panicked and started it and floored the motor, and suddenly the GEN light went out and I drove OK. I turned off the motor to go down a hill (like I always do to save gas) and when I tried to start it it did the same thing, GEN light, wouldn't run. Floored the motor again and I was OK. The truck has been running good, now, but I want to know-anyone know what happened?
PostPosted: Fri Jun 20, 2008 6:17 pm
Sounds like a Slipping belt. They may be worn and have a hard slick surface. I have seen pulley's get slick too. But that is not common. Check the belt.
PostPosted: Fri Jun 20, 2008 6:32 pm
I hope not! It's brand new! :esurprised
PostPosted: Fri Jun 20, 2008 8:55 pm
If the truck wont charge then the fuel pump shuts down.
PostPosted: Fri Jun 20, 2008 9:01 pm
Yeah thats it, its not a Gen light, its a no fuel pump light.
Check the wirring connectors. Both at the rear of the alternator and the one for the Regulator mounted on the inner guard.
On or the other will probably be cactus.
Bob.
PostPosted: Sat Jun 21, 2008 10:42 am
AH HA!!
That explains it my friend! Anyhow, it stopped doing it, so I am happy about that.. How could water keep my truck from charging?
PostPosted: Sat Jun 21, 2008 11:36 am
Electrical circuits do not like water.
The regualtor mounted on the inner guard of the luv is not sealed up. Its needs air to cool it i think.
Bob.
PostPosted: Sat Jun 21, 2008 12:05 pm
So you're saying I probably would have no use for a snorkel on my truck, eh?
PostPosted: Sun Jun 22, 2008 1:39 am
If its petrol there is probably no point what so ever.
If its diesel something can be done.
Bob.
PostPosted: Mon Jun 23, 2008 1:47 pm
No, I mean a snorkel for fording deep water with my 4x4 :) You know, so when the water level goes up over the hood the engine doesn't suck any water in.. :)
PostPosted: Mon Jun 23, 2008 8:03 pm
Tundrawolf wrote:
AH HA!!
Dang guys... That's why I love it here. I learn new $hit everyday.
PostPosted: Tue Jun 24, 2008 3:40 am
Your distributor will get wet about the same time the water gets high enough to get in the carb and your truck will stop.
Hence why i said what i said, theres really no point. Gas engines do not like running under water, the ignition system does not like it.
Not to mention you will have no charge again.
Bob.
