It is currently Mon Jun 08, 2026 10:33 am
 Post subject: Weber Carb rebuild kit
PostPosted: Sun May 11, 2008 10:47 pm
I use a Weber/Holley/Motorcraft 2 bbl on my '75 LUV. It's off an 80's 1.6L Ford Escort/Lynx. Runs bad at idle. Couldn't adjust it out so figured it's rebuild time. Spent a large part of today trying to find a carb kit on the net.
What I finally found is that this carb uses Tomco 5490B Rebuild Kit, and Tomco 734 Float Kit.
Carb is referred to as a model 740, disregarding the numbers on carb base which are 9537 1F23, and disregarding info that claims "It's a Ford part number 9510."
