It is currently Mon Jun 08, 2026 7:41 pm
 Post subject: 1980 Luv Loading up
PostPosted: Sat Nov 10, 2007 10:35 am
ok well there is one way for me to get around it loading up witch is letting it warm up but i cant let it warm up because when i start it it stals on me
i live in new york by the way so the weather has effect
so anyways it back fires or loads up every time i push in the clutch
problem 2
also the throtle sticks and ill let go of the gas to shift and it sticks meaning i have to push the pedal to the floor to get it unstuck witch leads to it loading up yet again and it sounds like 2 shotguns going off in my left ear
has anybody delt with this problem or have any advice for what i need or should do to stop this problem
thanks chris forette
PostPosted: Sat Nov 10, 2007 10:49 am
For the throttle sticking, check the cable. Have someone sit inside and push the peddle while you look at what is going on at the carb. (eng. off of coarse)
PostPosted: Sat Nov 10, 2007 10:56 am
will do thanks for your advice
My ride pics http://viewmorepics.myspace.com/index.c ... mId=829085
PostPosted: Sat Nov 10, 2007 2:12 pm
and spry sum wd-40 on all moving parts so they stay nice and lubed up
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Nov 14, 2007 10:20 pm
I've had mine stick in the winter a couple of times. But I think mine was ice buildup freezing the throttle shafts temporarily. I unstuck it by tapping the pedal a couple times. ( My warm air door actuator isn't working in the air cleaner, so on certain mornings I have stalling problems from ice freezing idle ports and such...)
