It is currently Mon Jun 08, 2026 10:33 am
 Post subject: colorado vs. LUV
PostPosted: Thu May 03, 2007 5:31 pm
Ive been looking at the colorados for a little while and will probably trade in my full size for one this weekend... most likely
but I have been seeing some simular things between the luvs and the co.'s
6 lug pattern (I have not measured either one)
fully boxed frame
7 crossmembers
Z71 uses torrsion bars ( I dont know if the 2wd Z71 uses them)
I just thought that was interesting
PostPosted: Thu May 03, 2007 5:35 pm
Banishment Pending
Colorado is based on the Isuzu D-Max platform...direct lineage to the Luv 8)
PostPosted: Fri May 04, 2007 7:57 am
If only they'd sell it with the D-Max engines!!!
PostPosted: Fri May 04, 2007 11:57 am
Banishment Pending
If only...I'd kill for the 3.0L DI TD :twisted:
PostPosted: Sat May 05, 2007 5:46 pm
If only they would bring back the LUV. They sell them out of the country. And if only they would actually build the trucks out of all steel and chrome, not plastic!
http://www.purerockradio.net/
PostPosted: Mon May 28, 2007 6:43 pm
anyone know what the wheel bolt patterns are?
I think the colorado is 6 x 5.5, the same as the LUV??
PostPosted: Tue May 29, 2007 5:08 am
Yep.
PostPosted: Tue May 29, 2007 10:42 am
I measured my full size and its the same too
8O
wierd
 Post subject: D-Max engines
PostPosted: Thu May 31, 2007 11:11 am
Has the D-Max motor been around for awhile?
Also is this the 07 Colorado's you are talking about?
Can you get the Colorado with a Xtra cab and 4WD?
