It is currently Mon Jun 08, 2026 10:33 am
 Post subject: BRAKE ?
PostPosted: Sun May 27, 2007 4:06 am
Australian LUV Guru
Image Image
Is the circled thing a bias valve? If so is mine built into the M cylinder?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun May 27, 2007 8:56 am
That looks like a pressure residual valve, the proportional valve may be on the other side and both of the lines from the master go to it, it also should have a wire going to the middle of it to work a brake warning light.
PostPosted: Sun May 27, 2007 9:20 am
If you have 4 wheel drums, would you even have a proportioning valve?
Where you put the circle, on mine the line goes out to the fender well and the valve is mounted there.
PostPosted: Sun May 27, 2007 9:27 am
It could be a preset prop. valve. Even drums all around had prop. valves with the duel master cause the fronts do about 60% of the braking.
PostPosted: Sun May 27, 2007 9:41 am
Boy! That white diesel eng. compartment is clean and lookin good.
PostPosted: Sun May 27, 2007 10:56 pm
Australian LUV Guru
I have disk front and drum rear.
