It is currently Mon Jun 08, 2026 3:29 pm
PostPosted: Tue May 08, 2007 5:43 pm
I just had a clutch master cylinder installed and the transmission now is whirling, when clutch is not pushed down, when pushed its quite when you let it out it make a noise and when you put in gear it is even more noticable, When the clutch is pushed while in motion it makes the noise also. Mechanic said the sounds like front trans bearing. Any ideas where to get these parts, or should I replace the whole trans. Anybody have a good 4 speed trans. Or Ideas please.
