It is currently Mon Jun 08, 2026 5:55 pm
 Post subject: Choke wire
PostPosted: Wed May 02, 2007 1:41 pm
Can someone tell me which color wire coming from the firewall harness goes to the Electronic choke on a 79? In my haste to install my carb I forgot to label, thought it would be obvious. But now i have a solenoid(I guess) and choke wire left... It's a Weber carb so all I need is the choke wire.
And, with a Weber, do I need the vac line from the intake to the small stem on the valve/crankcase cover?
Thanks
FIAA: Color Guard
PostPosted: Wed May 02, 2007 1:48 pm
It is the blue wire on mine.
 Post subject: .
PostPosted: Wed May 02, 2007 1:52 pm
Thanks, I'll verify the color on mine and try that, course I'm running great with no choke. Of course it is Texas :)
FIAA: Color Guard
PostPosted: Wed May 02, 2007 2:25 pm
If you still have your original Hitachi, the wire coming off the choke is colored, its just tucked underneath.
 Post subject: .
PostPosted: Wed May 02, 2007 4:04 pm
Got 'er done... Weber installed & tuned..... O M G!! Even sounds better now :)
FIAA: Color Guard
