It is currently Tue Jun 16, 2026 5:14 am
 Post subject: Idler arm bushings.
PostPosted: Sat Jan 27, 2024 9:21 pm
Hey all I'm trying to replace my idler arm bushings. So far I managed to get the idler arm off however I can't seem to get the 1-1/4" nut on top of the shaft to budge, is it welded? Do I need to remove this nut to replace the bushings? I'm assuming so.
 Post subject: Re: Idler arm bushings.
PostPosted: Mon Jan 29, 2024 10:00 pm
I can't remember for sure. What's on the other end of it. Is there a cover there? I think the large nut does hve to come off. I think I used a pipe wrench and cheater pipe on mine. It's not welded, just super tight. Hit it with penetrating oil once a day for a few days and add heat when trying to break it loose.
PostPosted: Tue Jan 30, 2024 2:24 pm
Thx for the response. I ended up just taking out the whole original mounting bracket and shaft and replacing it with one from a 85' trooper. Lined right up, all I had to do was drill the bolt holes out a bit larger.
PostPosted: Tue Jan 30, 2024 2:47 pm
Yeah, that nut needs to come off.
