It is currently Sat Apr 27, 2024 7:46 pm
PostPosted: Sat Jul 30, 2022 5:43 pm
I have a 79 4x4 four speed, needs rings and rebuilt valves, if i were to put in a new engine instead of rebuilding the g180 what would i be able to directly put in that mates correctly to the transmission and transfer case
Two 1979 4x4 4speed manual
- Strato White(4x4 decal)
- Light Blue
PostPosted: Mon Jan 09, 2023 11:28 am
You could use a early Isuzu Trooper motor 1984-1986, It will bolt to the transmission. Not sure on the motor mounts through. That might need fabrication.
