It is currently Wed May 22, 2024 10:35 am
PostPosted: Tue Nov 03, 2020 4:38 pm
Hi
I have a 1980 Isuzu KB (Chevy LUV) 2WD and I want to replace the front drum brakes with disc brakes. I saw you guys mentioned a 1985 Trooper 4x4's disc brakes would fit perfectly, but I can't get anywhere. Any advice where I can get? The old c190 engine is broken but the gearbox is fine. I found a ISUZU RODEO 2.0L c190 engine and just want to make sure it will fit on the original gearbox. The engine is a bit pricy, so if any other engines can fit please let me know. I am also looking for door windows left and right.
Regards
Hano
PostPosted: Wed Nov 04, 2020 10:50 am
Where are you located? The US LUVs had discs from 76 up.
PostPosted: Wed Nov 04, 2020 1:27 pm
I am in South Africa.
