It is currently Sun Jun 14, 2026 5:13 am
PostPosted: Mon Apr 27, 2020 7:18 pm
Hello all,
I just acquired 2 1980 chevy luvs. I'm currently working on one of them. I just installed a rebuilt carburetor and got it to turn on. It wont stay on without me stepping on the gas. The other problem I discovered today is that I noticed sparks coming the solenoid area (see pic). Any help would be appreciated. Thanks
PostPosted: Mon Apr 27, 2020 9:04 pm
If it’s coming from that stud/nut then it’s loose. Also, a ground strap might be missing.
PostPosted: Mon Apr 27, 2020 10:36 pm
Thanks! Yes. It's coming from that area around that nut. Whoever had it added a ground battery cable but left the other one.
PostPosted: Tue Apr 28, 2020 12:24 am
I forgot to mention that it does it when the car is on. Not just when starting. Possibly the same problem? I haven't tried tightening it. I will do that tomorrow and report back on my findings. thanks again
PostPosted: Tue May 05, 2020 8:23 am
Solved it! Thanks again
PostPosted: Tue May 12, 2020 8:38 pm
so what was the solution to the sparking problem
PostPosted: Wed May 13, 2020 7:00 am
As luverv8 suggested above, it was a loose bolt on the starter.
