It is currently Tue Jun 16, 2026 6:17 am
PostPosted: Sat Sep 09, 2017 6:16 pm
I have bought 3 lock and cylinders now, and they won't fit the doors of my new 1980 Luv. Is it possible that the doors could be from a different model? The doors on it have the triangular window at the front that swivels out.
Thanks in advance
1980 Chevy Luv (SBC350 and TH350 mounted!) front suspension install, trooper rear end with 4.10 gearing, needs driveline, brakes, and getting it running!
1968 Datsun Roadster - happy as ever!
1991 Nissan 300zx Twin Turbo (daily as possible)
PostPosted: Sat Sep 09, 2017 6:57 pm
I used the search feature and it indicated that wing Windows ended in the 77 model year. Does your source show a different part number from 77 compared to your 80 number?
PostPosted: Sat Sep 09, 2017 7:42 pm
There is no difference. I took the original door locks out of my 1976 vent window doors,and put them in the 1980 model non vent window doors that are on the truck now...
PostPosted: Sun Sep 10, 2017 11:43 am
I was afraid of that. I did see that wing windows ended earlier... But nothing about the locks. I'm not sure then why all the licks I've bought don't fit. I guess I'll try a 77 door lock and see what they say. Otherwise, there is something going on I don't understand.
Thanks
PostPosted: Sun Sep 10, 2017 1:27 pm
Are they right and left specific? Or all the same? Just throwing out a thought without checking the book first.
PostPosted: Sat Sep 16, 2017 11:35 pm
They don't say specifically, but I've tried both... Got some different locks that said they worked in other Gmc trucks.
. Still. Too bit... O'Reilly's mentioned being a little. More forceful... I'm. Worried it'd do damage...
PostPosted: Sat Sep 16, 2017 11:40 pm
They were built for GM by Isuzu. Might have better luck checking some Isuzu vehicles around that time frame... If you don't have a key for the locks in the doors that were in it, and still have the locks, take the cylinders to a lock smith and have them cut a key for them...
PostPosted: Sun Sep 17, 2017 12:20 am
Came not locks on the doors... Just holes... Everything I check brings up Chevy luv... I don't get it.
PostPosted: Sun Sep 17, 2017 9:55 am
The Chevy LUV was built by Isuzu and sold to Chevy to put their name on and sell in USA. Almost no other GM parts are going to fit your LUV. You might just have to find used locks and have a key made for them. I doubt you will find any new from the store locks for a LUV.
PostPosted: Sun Sep 17, 2017 10:03 am
The link looks to show the correct ones, and the keys look like the OEM style. May be able to use them as reference....
http://www.ebay.com/itm/Isuzu-KB20-KBD- ... gj&vxp=mtr
PostPosted: Mon Sep 18, 2017 12:01 pm
Thanks in advance
How sure are you them locks are for a Luv ... maybe post up a picture of your parts someone could notice a difference
here's the lock hole on 75 white - 80 red door & my 77 is the same
& PART #'S ON THE EBAY LINK ARE 1 # DIFFERENT IN THE 2 SO I GUESS LEFT /RIGHT LOCKS
PostPosted: Mon Jun 17, 2019 5:45 pm
The aftermarket locks have more material around the cylinder and are thicker. I had to Dremel the material to make it fit
PostPosted: Fri Jun 21, 2019 9:37 pm
I bought some from Amazon or Rockauto or something like that, and they were posted that they are for a LUV but they were GM cylinders to fit almost any GM vehicle from that era but we all know a LUV is not GM built and they didn't fit. They could be made to fit by making the door hole larger but I didn't want to do that.
PostPosted: Sat Jun 22, 2019 10:53 am
Why not just use 1st generation Isuzu Trooper locks?
