It is currently Tue May 07, 2024 1:13 am
PostPosted: Thu May 30, 2019 2:49 pm
i have a 79 luv with the 1.8 isuzu gas engine wich is brand new,distributor,coil,carb,fuel tank and lines all new.it will start but runs choppy and super rough give it gas sputters and dies.fuel pressure tests ok and can see tried a funnel with gas to be sure no change.im thinking electrical but not much to it coil has 12v dist has 12v points are gapped and new.firing order is correct from what i have looked up.ideas or suggestions need to fix thank you
PostPosted: Mon Jun 03, 2019 8:40 pm
Sounds like you may have a carburetor issue. I rebuilt my original carburetor myself to a so-so performance. Then to be certain it was right I bought a remanufactured OEM carb from a reputable rebuilder and had to send it back 3 times before I finally gave up and kept using my old one. Eventually I went with the Weber replacement carburetor. The original Hitachi carburetors are over complicated junk. Of course depending on where you live you may be stuck with it...
1977 LUV Barn-find. (And my favorite thing to drive!)
PostPosted: Tue Jun 04, 2019 9:13 pm
thank you for the help very much appreciated.i figured it out was a new distributor that was defective.replaced purs like a kitten
