It is currently Fri May 22, 2026 12:35 pm
 Post subject: carburetor, 1979
PostPosted: Thu Dec 27, 2018 7:16 am
anyone know of top two or three, or even the clear 'best' one, top pick replacement carburetor for a .04 bored-over, otherwise, stock engine (1979 LUV)? tk u.
 Post subject: Re: carburetor, 1979
PostPosted: Thu Dec 27, 2018 1:38 pm
The standard Weber would still be in the top 3 at least. Probably top one when you consider cost.
I mean, it's what goes on the high performance 2.0 Ford engines out of the Pinto/Mustang II. I believe it's also what they use on the top of the racing Cosworth engines that were pre-EFI.
It's arguably the best 2 barrel carb out there. There are some that would out perform it at the top end of BHP, but they are prohibitively expensive.
PostPosted: Thu Dec 27, 2018 9:10 pm
Tk u lots
PostPosted: Tue Jan 01, 2019 5:34 pm
You can't go wrong with the 32/36 DGV Weber. Either with manual or electric choke. Your choice.
