It is currently Fri May 22, 2026 12:35 pm
PostPosted: Fri Dec 28, 2018 10:43 am
I have a 1973 (Titled) Fleetside Chevy Luv with 1982 Evenfire Buck V-6 (Aprox 30K Since New) rebuilt 2bbl Carb, P/S Pump, Alt, 14" electrical Cooling Fan/Cored Out Chevy Luv Radiator with Auto Off-On Temp Switch. Motor is mated to 700R4 Automatic Trans Mated to A Model 20 Transfer Case. New Front/Rear Drivelines, Front Dana 44 Axle 6-Lug (60"S Wide With 1.5" wide wheel spacers) 4.88 Gearing with Limited Slip, Parks Mike Crossover Steering, all new wheel bearings and upper/lower ball joints, rotors, steel braided brake lines, Rear 6-Lug Tacoma 60" wide with New 4.88 Gears and Factory E-Locker (with new 12 volt Guy E-Locker wiring Harness) 37" Super Swamper Boggers mounted on 15 x 12 Alloy Wheels, Kc Daylighter Smiley Face Fog Lights and covers, Retro Smitty-Bilt Double/Single rollbar and a windshild sun visor.
I purchased this from a friend who did the build.
find it here.
http: //webilt.com/forum3/viewtopic.php?f=4&t=1589&hilit=luv
Additionally:
We have
a set of Xtreme rims with worn 37x13.5R18LT Toyo's (Need New Rubber)
2 extra qt. cooling pan for 700R trans along with a trans temp gauge.
1979 stepside Chevy Luv bed, two 1979 chevy luv doors, one 1979 Chevy Luv driver side front fender.
I would like to sell
you can contact me by txt or phone
nine one six two 0 seven two four seven 0
