It is currently Wed Jun 10, 2026 4:08 am
 Post subject: New owner
PostPosted: Sat Jun 09, 2018 6:16 pm
Just bought a 79 4x4 for $650. Supposedly just has carb issues. No real plans yet but I'm super excited to get some looks and here and figure out what route I want to go. Basically it'll be a little truck to haul my dirtbike around. I look forward to seeing what this forum has to offer.
 Post subject: Re: New owner
PostPosted: Sun Jun 10, 2018 10:15 am
Welcome.
Most carb issues with these trucks can be solved by putting a Weber on in its place. Next in line is to remove the points and condenser and put a Pertronix electronic ignition module in.
Keep a watchful eye on the CV joint boots on the front axle. The CV joints are no longer available. Which means a torn boot left too long will leave you with a 2WD truck. The boots are replaceable and still available from multiple sources.
PostPosted: Tue Jun 12, 2018 6:23 pm
Thanks Mickey_D. I pick it up this weekend so hopefully the cx axles aren't bad. Just might have to build a drag truck if they are.
