It is currently Wed Jun 10, 2026 11:14 am
 Post subject: Newbie LUV owner!
PostPosted: Sun Apr 29, 2018 8:25 am
Hey hey, I am a new member and new LUV owner, picked up a stock 79’ 4x4 recently. No real questions yet but looks like a fun truck and stoked to get it on the road. Any advice? I sort of like the stock survivor look and won’t be doing any off-road so planning on keeping it unmolested. Better tires might be in order, haven’t found much info on AT type tires for the OEM wheels, any suggestions?
 Post subject: Re: Newbie LUV owner!
PostPosted: Sun Apr 29, 2018 9:09 am
welcome.as far as wheels and tires,my 79 had been buried in mud for some time before I got it,and the rims were rusted nearly through.Even the steel belts rusted through,deforming the tires. I bought new "trailer" wheels in 15" and that of course gives you unlimited tire choice. good luck
PostPosted: Mon Apr 30, 2018 1:31 am
If you still have the original 14" wheels, believe it or not the Walmart Douglas Xtra Trac tires are phenomenal. Between my wife and I we've used them on 3 vehicles.
But don't go get them if you're running 15" wheels. For some reason they are absolute crap.
But, the 14"? Best damned tire I've had in a long while. And that includes the 31" BFGoodrich A/T's that are on my Jeep right now. Those Walmart specials are top notch on the highway, get good traction on wet roads (very important here north of Seattle), and do better in the snow than anything less than an $800 set of studded snows (Blizzak).
Oh, and the last set my wife had on her Neon? 45,000 miles and still no sign of the wear indicators...
PostPosted: Mon Apr 30, 2018 8:20 am
I might look into 15’s and would be interested if I could find something that looked accurate to the trucks original look, did LUV’s have an option for a 15” wheel when new?
PostPosted: Mon Apr 30, 2018 8:22 am
Wonderful, I will check them out, I read that General makes a 205 x 14 x 8.5 not sure if it will clear the fenders. Might be an option.
PostPosted: Mon Apr 30, 2018 11:05 am
My son got a set of Maxxis Bighorn tires through Pep Boys. he had to order them, and they are on stock 14" rims. He likes them.
PostPosted: Mon Apr 30, 2018 1:06 pm
Cool, thanks, I will check them out.
PostPosted: Mon Apr 30, 2018 7:27 pm
welcome. luvs never came stock with 15's as far as i know.....but after doing a lot of searching there are old toyota fj40 steel wheels that look dang close to the stock luv 4x4 wheels except theyre 15s, same bolt circle too! thinking about getting some for mine??
1979-chevrolet-4x4-luv-pickup-truck-e1434743009471.jpg [ 205.92 KiB | Viewed 15343 times ]
PostPosted: Tue May 01, 2018 11:24 am
Very cool, nice find and good idea, assuming the red truck is stock with the 14’s? Is there any problems with running 15’s.?
PostPosted: Tue May 01, 2018 11:40 am
red truck is stock 14's. There are no problems running 15's, unless un-sprung weight is a concern for you.
PostPosted: Tue May 01, 2018 1:01 pm
It's not the diameter of the wheel that will pose a problem.
A 185/60/15 (stock on a Neon) is smaller in diameter than a 205/70/14 (which is stock for a Luv), but the wheel is bigger.
It's the tire that matters and a stock 205/70/14 is roughly the same outer diameter and width as a 185/75/15.
PostPosted: Tue May 01, 2018 1:24 pm
True. though I run 215 75r15 bfg all terrains...27.5" roughly...and there's plenty of room...still looks appropriate. use the conversion 215 divided by 25.4 times aspect ratio..in this case 0.75= sidewall height x2 for both sides of wheel ...plus wheel size 15" = overall diameter in inches
PostPosted: Tue May 01, 2018 3:46 pm
Heh, I just let Discount Tire do all the calculations for me with their handy page.
PostPosted: Tue May 01, 2018 4:28 pm
I dug around a bit and they are pretty pricey, at least the new / refinished wheel is, they would look good though.
https://shop.cruiserparts.net/index.php?main_page=product_info&cPath=2_4853_4495_5791_5837&products_id=994&zenid=1b6e79ae41e1ac556aed3051db2d71c3
PostPosted: Tue May 01, 2018 6:20 pm
America’s Tire (Discount tire) has the wagon wheel spoke rims, last time I checked around $60 a piece.
PostPosted: Tue May 01, 2018 6:38 pm
That is a bit spendy for those fj40 wheels :esurprised ....ive seen them for cheaper somewhere...i'll take a look. here's a photo of my wheel and tire set up if it helps. 215 75r15 or 27.5
PostPosted: Tue May 01, 2018 8:10 pm
Very cool, looks awesome! Any other pics of your truck around I can take a peek at?
PostPosted: Tue May 01, 2018 8:55 pm
Thanks . heres one as she sits now, in progress...motor is out that's why the front is sitting a tad high.
PostPosted: Wed May 02, 2018 8:14 am
Nice looking truck! Very cool, are you restoring it? Mostly a stock build? Love the color! I am very new to trucks and LUVs. Have been interested in getting a 60's/70's micro truck and was looking at Datsun, hilux and wound up with a LUV survivor 4x4. Slightly different direction than I had intended.
PostPosted: Wed May 02, 2018 11:40 am
Thanks. Yea, she's mostly stock. I'm putting a g200 in her in place of the g180. The color isn't stock, I was actually trying to match a Datsun 521/620 color. I'd really like to see some pictures of your LUV survivor!! 8)
