It is currently Sat Mar 28, 2026 5:45 am
PostPosted: Mon Mar 27, 2017 3:25 pm
will a later model 1976-1982 Chevy Luv motor and tranny bolt into a 1974 chassis.
PostPosted: Mon Mar 27, 2017 3:35 pm
Yes, I put a 77-78 motor in a 75 & the motor mounts were a little problem but went in & got it running Ok (then they wanted to not pass smog w/ the newer motor ) the oil filter had to be relocated. ... I later got a 77 and swapped everything to it.
here it is installed
PostPosted: Wed Mar 29, 2017 10:03 pm
You had to smog a 75 in CA? I thought it was exempt.
PostPosted: Wed Mar 29, 2017 11:09 pm
Yea, i was asking the same question & i wasn't liking the answer either but Yes, since I put a 77-78 motor ... and that's what was being smogged
