It is currently Sat Mar 28, 2026 11:45 am
PostPosted: Tue Jan 10, 2017 7:37 pm
Hi all,
I tore down the stock g180 because of a blown head gasket. A bit of gasket between 3&4 sucked into the combustion chamber and it started knocking and lost all power.
Anyhoot, I've torn the whole damn thing apart, cleaned everything up, replaced all the bearings and have been putting it back together since September. But now I'm at a roadblock. The old cylinder head was toast, I pulled another that is in way better shape, but I forgot to nab the little dowel pin things that go between the CH and the block. I've looked hi and low on the internets and can"t get the proper info.
Is it a generic part that I can get anywhere or is it specific?
Thanks a bunch,
-Pony
Pony | 1980 Chevy Luv
PostPosted: Sun Feb 19, 2017 12:09 am
I made one by finding a bit of aluminum tube. cut it to length. dremeled a line through it. cleared all the burrs off and it seems to work.
