It is currently Sat Mar 28, 2026 1:07 am
 Post subject: front rotor change
PostPosted: Tue Nov 22, 2016 3:39 pm
Hello,
I have a 76 chevy luv that I putting a 10 bolt rear end in and would like to have the same bolt pattern on the front and rear wheels. the 10 bolt is 5 by 4.5" (standard) but the stock front rotors are 6 lug. Does anyone know if there is a replacement rotor that has the same bearings, spindle size, and rotor size I can use so I don't have to replace the calipers and mounts? Thanks in advance for anyone's help!
 Post subject: Re: front rotor change
PostPosted: Tue Nov 22, 2016 10:51 pm
viewtopic.php?f=8&t=27266
