It is currently Sat Mar 28, 2026 4:20 am
PostPosted: Wed Aug 24, 2016 10:56 pm
Alright I bought this luv from a buddy. Its been sitting in a field for quite a while now. They couldnt find the title and I have yet to title 42 it so im not positive on the year. It has a 350 with a turbo 350 trans and a Ford 9" rearend. Needless to say theres already been a lot of stuff changed on it. Anyways Ive went through everything to try and get it to start. It has the in dash key ignition but when i try to turn the engine over all the lights shut off and fans and wont do anything. I can not figure out what is causing this, when i jump the starter it turns over that way i just cant get it to do so with the key. Also is there any way to easily determine the year other than title 42? Thanks for any help in advance. This is thr truck havent made it to setting up my stuff yet.
PostPosted: Thu Aug 25, 2016 6:24 pm
FOR THE YEAR THE 6th position of the door jam tag > CLN13 "6" Will tell you the YR / SERIES #
Series 5= 1976, Series 6 = 1977 "NO Series 7" & Series 8 = 1978
PostPosted: Fri Aug 26, 2016 1:03 pm
Alright then I guess its an 82, vin is CLN14282. I assume thats what you mean, thank you.
PostPosted: Fri Aug 26, 2016 1:38 pm
Nope that would be a series 8, which would make it a 1978. 81 and 82 are completely different body styles.
PostPosted: Fri Aug 26, 2016 2:22 pm
Oh ok yeah i thought they were different I didnt really understand what he was meaning. Thank you
PostPosted: Fri Aug 26, 2016 8:02 pm
Okay,I've never gotten into decoding the VINs,but.........
Reading this thread just made my head hurt...LOL
First,If 3rdluv's info is correct,the 6th(digit I assume) is the series number,then according to the owner's post it would make it a 73.
If the series number in the VIN is the 7th digit,then it would make it a 79.
After reading the OP's original description and looking at the pic,the truck's been highly modified, therefore without more info/pics it's going to be a little difficult to figure out exactly what year the cab and chassis are.
PostPosted: Sat Aug 27, 2016 5:29 pm
Disregard my post,musta had too many beers last night .....LOl
But it still doesn't make sense.
PostPosted: Sun Aug 28, 2016 11:47 am
i read your " CLN14282 " as a Series 2
Here is a previous link that share more info :
viewtopic.php?f=5&t=6862&st=0&sk=t&sd=a&hilit=vinJust a quick VIN note on how to tell the year:
Series------Pickup Chassis------Cab Chassis------4WD
Series 1----LUV 82
Series 2----CLN14282
Series 3----CLN14382
Series 4----CLN14482
Series 5----CLN14582-----------CLN13582
Series 6----CLN14682-----------CLN13682
Series 8----CLN14882-----------CLN13882
Series 9----CLN14982-----------CLN13982--------CRN14982
Series 10---CLN14A82----------CLN13A82--------CRN14A82
PostPosted: Thu Sep 01, 2016 8:26 pm
Alright well I guess its a 73? Lol Idk Anyways I got the starting issue figured out. Neutral safety crap
