It is currently Sat Mar 28, 2026 4:07 am
PostPosted: Fri Jun 19, 2015 4:01 pm
I am seeking any year LUV or Isuzu chassis torsion bar front drum or disc and the stock rear axle and all suspension. I would hope for the best price as I am building from the ground up. Thanks for any help on this.
PostPosted: Fri Jun 19, 2015 7:48 pm
Welcome, this is definitely the place to search. Kudos for remembering to post your location. You'd be surprised how many folks forget that little detail, and a rolling frame doesn't exactly fit the USPS flat rate "If it fits, it ships" box. ;) If you're looking for a 2nd gen frame, I could point you to some possible sources, but if 1st gen, this site alone is your best hope.
PostPosted: Fri Jun 19, 2015 7:51 pm
I'd be interested i the 2nd gen. if the frames are same width and track as well as torsion bar low tower design front IFS ?
PostPosted: Fri Jun 19, 2015 8:05 pm
Someone else will have to answer that one, because I know pretty much zero about the 1st gen.
PostPosted: Sun Dec 20, 2015 9:24 am
I will be having a truck I used for parts the frame is not in the best of shape but it is 4 wheel drum and a roller its a 73 luv.
Motor trans and the rest of the parts I didn't use I could let you have for $500 the problem is that I am in Indiana and it is still at the body shop.
send me a email at dseed69@hotmail.com if your interested.
PostPosted: Tue Nov 22, 2016 3:35 pm
I have a stock rear end I just took out of my 76, I am in southern California. if you are close and want to look at it let me know. I am putting a V8, 700r trans, and a chevy 10 bolt rear end, thanks.
craig
