It is currently Mon Jun 08, 2026 7:18 am
 Post subject: Headers
PostPosted: Wed Oct 29, 2014 6:19 pm
hi,first time here.lots of good info but have searched around and cant seem to find an answer to my question,so here goes.i need off the shelf headers,prefer 1 3/4,long tube,inside frame.my truck is '80 Luv,406sbc,dart ANGLE plug heads(difficult part)...I have the luv conversion headers and they wont work with the angle plugs.no torsion bars(coilover conversion)thanks to info I got on this site.thanks for any help yall can give
 Post subject: Re: Headers
PostPosted: Wed Oct 29, 2014 11:03 pm
No off the shelf in that size, or in frame. I don't see it happening in custom built either without some firewall mods to make room for all the tubes...
PostPosted: Thu Oct 30, 2014 2:29 pm
Ok.thanks for response.
PostPosted: Thu Oct 30, 2014 4:14 pm
You can make the Hookers work buy rotating a couple of tubes . Gonna need a chassis shop to make them right though . I would then have them coated .
PostPosted: Thu Oct 30, 2014 5:29 pm
thanks.im gonna have to try something else cause my hookers block 2nd plug on lt side and hit oil pan(7qt) and block drain plug on rt side
PostPosted: Wed Nov 26, 2014 1:11 pm
Custom made headers are in the $1200 range. Ouch.... My buddy has some made for his Competition Eliminator class car. but nothing on those are cheap.
PostPosted: Thu Nov 27, 2014 12:32 am
I had 2 cut both sides and add couplings to them to get the 2nd plugs to clear . My drain plug is tight to get out and the oil filter is a pain to get in and out .
PostPosted: Tue Dec 09, 2014 5:41 pm
Might be better off using some block hugger headers. Speedway motors catalog has some nice ones.
