It is currently Mon Jun 08, 2026 10:15 am
PostPosted: Wed Sep 03, 2014 6:59 pm
Traded a non running Suburban for this a couple weeks ago. Been using it as a daily, seems to be doing fine (knock on wood) but it has started to begin overheating only when moving. Stop at a light, it climbs right down. And when I turn the lights on it starts climbing a lot faster and sometimes stays up there. I have heard the voltage regulator is bad, clogged radiator, and bad alternator
PostPosted: Thu Sep 04, 2014 2:35 am
sounds like an electrical issue. my fuel gauge doesn't work but I had some burnt wiring and when I hit the brake it slowly climbed to full and stayed there a bit it could be an electrical system fault, if you have a multimeter and can check the voltage output from your alt and after the regulator.
PostPosted: Fri Sep 05, 2014 12:26 am
Fan/alternator belt loose and slipping.
PostPosted: Fri Sep 05, 2014 7:46 am
I think egg hit it.
Tom
PostPosted: Thu Oct 09, 2014 9:10 pm
I'm wondering if this is my issue... Gonna check it tomorrow.
