It is currently Fri May 10, 2024 4:03 am
 Post subject: She's Eating Fuses.
PostPosted: Thu May 15, 2014 2:05 pm
So, I'm brand new to Luv trucks, I have a '79 2WD. She was running fine when I got her, but about a week ago she started blowing the Voltage Regulator Fuse. I replaced the Regulator and it seemed to fix the problem, right up until it started happening again. This time I took the Alternator in and tested it finding it to be bad, so I replaced it. But still the same problem. I replaced the new Regulator again, as it was under warranty, just to see if the bad Alternator fried the new Regulator. But still keeps blowing the Regulator fuse.
I also am going to note that I have replaced the old Carb with a brand New Weber one, but this problem was happening and "Fixed" before I installed it.
Has anyone else encountered this problem or has some insight? I really could use an extra opinion.
 Post subject: Re: She's Eating Fuses.
PostPosted: Fri May 16, 2014 12:36 am
May not be the regulator as that fuse also operates the fuel pump, fuel pump relay, and the ignition bypass relay.
Fuel pump may be a likely suspect.
PostPosted: Sat May 17, 2014 9:46 pm
SO after some tinkering around, she randomly stopped having this issue. But thank's Anyways! Ill keep that in mind if it happens again.
'79 Luv 2wd, Daily Driven Project
