It is currently Sun Jun 14, 2026 7:30 am
 Post subject: Getting my first Luv
PostPosted: Wed Apr 16, 2014 8:53 pm
Hello all!
This Sunday I'm going to pick up my first Luv. Its a 1980 4x4. I wanted to get some information on these trucks so I know specific things to look for when I get it. So my question is, other than the standard engine running and exhaust what should I watch out for? I am told that it runs good, has no exhaust leaks, and has a straight body and chassis.
It looks pretty clean other than some faded paint and the owner telling me the wheels are old and need replacing.
Thanks in advance,
BC
http://images.craigslist.org/00t0t_3Sju ... 00x450.jpg
http://images.craigslist.org/00c0c_kzsC ... 00x450.jpg
http://images.craigslist.org/00v0v_kGUO ... 00x450.jpg
 Post subject: Re: Getting my first Luv
PostPosted: Wed Apr 16, 2014 10:13 pm
looks pretty good and straight i think i have that same toolbox in my garage too
look at the heater core valve located on the driver side near the cylinder head they leak really often. not a big deal but it is annoying and can drip into the cab
if it has the stock carb check that it works well they can have a lot of issues i went thru three of them said screw it and got a weber.
obvious stuff like any fluid leaks, really dirty oil, filters etc see if it has been well maintained
also pop the radiator cap and see if there is a lot of crud in there they can get clogged up and cause overheating issues
the usual list of stuff your lookin for from a truck in the 70s
looks like that is a pretty good truck to start with
PostPosted: Wed Apr 16, 2014 10:18 pm
Below the doors on the cab is called rocker panels. Make sure they are not rusted out. Those are parts not available and have to be made to fit, it's a big job. Pull up the carpet on the floors where your feet would sit, again look for rust.
What is he asking for it? Post up a link to the craigslist ad.
EDIT, never mind, I found it. The price looks good
http://portland.craigslist.org/clc/cto/4417315569.html
PostPosted: Wed Apr 30, 2014 9:10 am
Did he ever get the truck
